Inleiding
The SD card stores videos and images that you record on your camera. You should remove the battery and SD card before opening the camera to access the screen,motherboard, flash, lens, or any other internal part of the camera.
  1. Slide the bottom panel in the direction of the arrow on the panel.
    • Slide the bottom panel in the direction of the arrow on the panel.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  3. Pull/lift open the battery cover in the direction directly away from the camera.
    • Pull/lift open the battery cover in the direction directly away from the camera.
  4. Push down on the SD card next to the battery in order to release the SD card.
    • Push down on the SD card next to the battery in order to release the SD card.
    • Pull the SD memory card out of the camera in the same way that you would pull out the battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Zoe Hinck
29 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-19, Amido Spring 2012 Lid van Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 Leden
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 806
