Ga door naar hoofdinhoud
Panasonic D-snap SV-AV50 Lens Replacement
Wat je nodig hebt
  1. Panasonic D-snap SV-AV50 Lens Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the bottom panel in the direction of the arrow on the panel.
  2. Panasonic D-snap SV-AV50 Lens Replacement: stap 2, afbeelding 1 van 1
    • Pull/lift open the battery cover in the direction directly away from the camera.
  3. Panasonic D-snap SV-AV50 Lens Replacement: stap 3, afbeelding 1 van 1
    • Push the small gray plastic tab away from the battery in order to release the battery.
  4. Panasonic D-snap SV-AV50 Lens Replacement: stap 4, afbeelding 1 van 1
    • Pull the battery out of the camera.
  5. Panasonic D-snap SV-AV50 Lens Replacement, SD Card: stap 5, afbeelding 1 van 1
  6. Panasonic D-snap SV-AV50 Lens Replacement: stap 6, afbeelding 1 van 1
  7. Panasonic D-snap SV-AV50 Lens Replacement: stap 7, afbeelding 1 van 1
    • Push down on the SD card next to the battery in order to release the SD card.
    • Pull the SD memory card out of the camera in the same way that you would pull out the battery.
  8. Panasonic D-snap SV-AV50 Lens Replacement, Motherboard: stap 8, afbeelding 1 van 1
  9. Panasonic D-snap SV-AV50 Lens Replacement: stap 9, afbeelding 1 van 1
  10. Panasonic D-snap SV-AV50 Lens Replacement: stap 10, afbeelding 1 van 1
    • Remove the two screws (2.2mm Philips) indicated.
  11. Panasonic D-snap SV-AV50 Lens Replacement: stap 11, afbeelding 1 van 1
    • Remove the piece of the frame that covers the camera's function buttons by pulling upwards from the end, as shown in the picture.
    • It may feel like you are breaking the camera, since the frame makes a snapping sound as you remove it. However, as long as you are careful to remove the frames individually as shown, the frames will probably not break.
  12. Panasonic D-snap SV-AV50 Lens Replacement: stap 12, afbeelding 1 van 1
    • Turn the camera and remove the frame from the opposite side of the camera by pulling from either the top or the bottom in an outwards direction.
    • As in the previous step, it may seem like you are breaking the camera, because the frame makes snapping noises, as you pull it apart.This is to be expected, and will not harm the camera.
  13. Panasonic D-snap SV-AV50 Lens Replacement: stap 13, afbeelding 1 van 1
    • Remove the two screws (4.08mm" Philips) that are indicated in the picture.
    • Flip the camera 180 degrees and remove the corresponding screws on the opposite side of the camera
  14. Panasonic D-snap SV-AV50 Lens Replacement: stap 14, afbeelding 1 van 1
    • Remove the backing of the camera from the side opposite the screen
    • To make it easier for yourself, pull the screen outwards from the bottom of the camera, near the battery cover.
  15. Panasonic D-snap SV-AV50 Lens Replacement: stap 15, afbeelding 1 van 1
    • Remove the small cover from near the top of the motherboard, using tweezers or forceps, as in the picture.
  16. Panasonic D-snap SV-AV50 Lens Replacement: stap 16, afbeelding 1 van 1
    • Unscrew the two screws (5.18mm Philips) indicated by the picture.
  17. Panasonic D-snap SV-AV50 Lens Replacement: stap 17, afbeelding 1 van 1
    • Carefully remove the motherboard from the camera by grasping the sides and pulling upwards and then outwards.
  18. Panasonic D-snap SV-AV50 Lens Replacement, Flash: stap 18, afbeelding 1 van 1
    • Remove the top piece of the casing from the camera, as shown in the picture.
  19. Panasonic D-snap SV-AV50 Lens Replacement: stap 19, afbeelding 1 van 1
    • Carefully remove the top most piece of the upper frame as indicated in the picture.
    • You may need to manipulate the pieces of the frame until they disconnect from one another.
    • The two side pieces should "fall" off after this piece is removed.
  20. Panasonic D-snap SV-AV50 Lens Replacement: stap 20, afbeelding 1 van 1
    • This is what the flash looks like.
  21. Panasonic D-snap SV-AV50 Lens Replacement, Lens: stap 21, afbeelding 1 van 1
    • Press in the "realease" tab to rotate the lens and screen 90 degrees.
    • Remove the two screws(from left to right; 5.23mm Philips, 2.1mm Philips) indicated.
    • Flip the camera over 180 degrees and remove the same screws that are on the other side.
  22. Panasonic D-snap SV-AV50 Lens Replacement: stap 22, afbeelding 1 van 1
    • Carefully remove the bottom of the lens casing by pulling downwards away from the lens.
  23. Panasonic D-snap SV-AV50 Lens Replacement: stap 23, afbeelding 1 van 1
    • Carefully remove the other side of the lens casing by pulling it away from the lens, and make sure to keep attached to the wire it is connected to.
  24. Panasonic D-snap SV-AV50 Lens Replacement: stap 24, afbeelding 1 van 1
    • Making sure not to break anything; grab the lens unit with a forefinger and a thumb and gently pull outwards away from the camera.
    • The lens will 'pop' out of the small metal frame that is holding it.
  25. Panasonic D-snap SV-AV50 Lens Replacement: stap 25, afbeelding 1 van 1
    • To install a new lens, simply follow the previous directions in a reverse order.
Conclusie
Bryan
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-19, Amido Spring 2012 Lid van Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 915
