Inleiding
This repair guide will show you the best step by step procedure of how to replace your power button in your Panasonic ARC ES-LT3N. The process is fairly easy and you only need a one tool!
Wat je nodig hebt
Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
Bijna klaar!
Conclusie
