Ga door naar hoofdinhoud
PalmOne Zire 72 Control Pad Replacement
Wat je nodig hebt
  1. PalmOne Zire 72 Control Pad Replacement, Control Pad: stap 1, afbeelding 1 van 2 PalmOne Zire 72 Control Pad Replacement, Control Pad: stap 1, afbeelding 2 van 2
    • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
  2. PalmOne Zire 72 Control Pad Replacement: stap 2, afbeelding 1 van 1
    • Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
    • If you peel the entire adhesive off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
    • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
  3. PalmOne Zire 72 Control Pad Replacement: stap 3, afbeelding 1 van 1
    • Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
  4. PalmOne Zire 72 Control Pad Replacement: stap 4, afbeelding 1 van 1
    • Use either end of the spudger to carefully pry off the camera lens mesh cover.
  5. PalmOne Zire 72 Control Pad Replacement: stap 5, afbeelding 1 van 1
    • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
  6. PalmOne Zire 72 Control Pad Replacement: stap 6, afbeelding 1 van 2 PalmOne Zire 72 Control Pad Replacement: stap 6, afbeelding 2 van 2
    • Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
    • Gently remove the case to avoid damaging it. Do not try to force the case open.
    • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
  7. PalmOne Zire 72 Control Pad Replacement: stap 7, afbeelding 1 van 2 PalmOne Zire 72 Control Pad Replacement: stap 7, afbeelding 2 van 2
    • Remove the cover by lifting it from right to left.
    • This should be similar to the action of the opening of a book.
    • The brown film connecting the motherboard to the screen may tear if this is not done carefully.
  8. PalmOne Zire 72 Control Pad Replacement: stap 8, afbeelding 1 van 1
    • Lift the control pad buttons off of the motherboard.
Conclusie
Michelle Medina
63 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-49, Amido Spring 2012 Lid van Cal Poly, Team 6-49, Amido Spring 2012
CPSU-AMIDO-S12S6G49
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 425
