Ga door naar hoofdinhoud
Palm v Outer Case Replacement
Wat je nodig hebt
  1. Palm v Outer Case Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Lay device face down on surface.
  2. Palm v Outer Case Replacement: stap 2, afbeelding 1 van 2 Palm v Outer Case Replacement: stap 2, afbeelding 2 van 2
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Outer Case Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Outer Case Replacement: stap 4, afbeelding 1 van 1
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Outer Case Replacement: stap 5, afbeelding 1 van 3 Palm v Outer Case Replacement: stap 5, afbeelding 2 van 3 Palm v Outer Case Replacement: stap 5, afbeelding 3 van 3
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
Eindstreep
Anthony Platt
66 Reputatie
3 handleidingen geschreven
Cal Poly, Team 13-25, Maness Winter 2010 Lid van Cal Poly, Team 13-25, Maness Winter 2010
CPSU-MANESS-W10S13G25
4 Leden
4 handleidingen geschreven
Één opmerking
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,619
