Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Heat the left and top edges with hairdryer for one minute.
Move hairdryer back and forth to evenly heat up surface.
Use tweezers to hold Palm right side down on it's side.
Use a plastic opening tool to pry open front and back casing.
Leave plastic opening tools in between front and back casing.
Rotate Palm and repeat steps 2 and 3 for right and back edges.
Now pry open front and back casing with plastic opening tools.
Separate front and back casing completely.
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
Now you must flip up the adjacent clamp as well, using tweezers like before.
After the clamp is flipped you can gently remove the second ribbon with tweezers.
Before removing the screen you must detach one more wire, the battery connector.
Using the tweezers, squeeze the connector attached to the wire and genlty pull.
Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
Lay screen face down so the battery is facing upwards.
Cover the upper back portion of the device so the battery is the only exposed part.
Use the hairdryer to heat each side of the battery for at least 30 seconds.
Using the tweezers or the spudger, pry off the battery from the screen.
3 andere personen hebben deze handleiding voltooid.
