Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the stylus from the side of the PDA by sliding it upwards.
Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
Carefully and forcefully pry the panels apart.
Use tweezers to unplug the battery cable from the motherboard socket.
Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
Use the plastic opening tool to pry the orange clamp away from the motherboard.
Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
Pull the LCD screen up from the bottom of the device using your forefinger.
The LCD screen will easily come away from the front panel.
Één andere persoon heeft deze handleiding voltooid.
