Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Before you begin disassembly, be sure to have the necessary tools. You will need a Torx size T6 screwdriver, tweezers, and the device opening tool. You will be removing the stylus, the back panel, the battery, and the motherboard in order to access the LCD screen.
  1. Remove the stylus from the side of the PDA by sliding it upwards.
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver. Place screws in a plastic bag or another safe place.
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. LCD iPhone-scherm fixkits
    De goedkope optie, ondersteund door onze levenslange garantie.
    Koop kits
    Bespaar op reparatiekosten, niet op kwaliteit.
    Koop kits
  4. Insert the edge of the plastic opening tool between the back panel and the black stylus holder. Carefully and forcefully pry the panels apart. Carefully and forcefully pry the panels apart.
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  5. Use tweezers to unplug the battery cable from the motherboard socket. Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards. The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
  6. Use the plastic opening tool to pry the orange clamp away from the motherboard. Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate. Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
    • Use the plastic opening tool to pry the orange clamp away from the motherboard.
    • Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
    • Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
  7. Pull the LCD screen up from the bottom of the device using your forefinger. The LCD screen will easily come away from the front panel.
    • Pull the LCD screen up from the bottom of the device using your forefinger.
    • The LCD screen will easily come away from the front panel.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Miles Johnson
541 Reputatie
4 handleidingen geschreven
Cal Poly, Team 14-9, Forte Winter 2011 Lid van Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Leden
6 handleidingen geschreven
Één commentaar
The hardest part is getting the back plate off, I throttled my plastic spudger.
dpchoung - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,749
