Inleiding
Before you begin disassembly, be sure to have the necessary tools. You will need a Torx size T6 screwdriver, tweezers, and the device opening tool. You will remove the stylus and back plate in order to access the battery.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers to unplug the battery cable from the motherboard socket.
Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
6 andere personen hebben deze handleiding voltooid.
