Ga door naar hoofdinhoud
Palm m105 Button Replacement
Wat je nodig hebt
  1. Palm m105 Button Replacement, Buttons: stap 1, afbeelding 1 van 1
    • Begin with the Palm m105 facing you on a flat surface.
  2. Palm m105 Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the protective screen cover by flipping it up and pulling it directly away from the top of the device.
    • The two clips located on the protective screen should pop out.
  3. Palm m105 Button Replacement: stap 3, afbeelding 1 van 1
    • To remove the faceplate, lift the tab located at the top of the device.
    • The faceplate should easily lift off.
  4. Palm m105 Button Replacement: stap 4, afbeelding 1 van 3 Palm m105 Button Replacement: stap 4, afbeelding 2 van 3 Palm m105 Button Replacement: stap 4, afbeelding 3 van 3
    • Using a T-5 Torx screwdriver, remove all four screws located on the back of the device. Turn counterclockwise to remove screws. The link to purchase this screwdriver is located at the top of this page.
    • Once you have removed all four screws, the device will be in three separate pieces (the back, the computer, and the button board).
    • Take caution as the power button will become loose after this step is completed.
  5. Palm m105 Button Replacement: stap 5, afbeelding 1 van 1
    • After step four, locate the button board. The button board should have a frame attached to it. Remove this frame.
    • To remove the buttons from the frame, apply even pressure on two buttons at a time. This should make them pop out easily. Once you have removed the buttons, you can now wash or replace them.
    • To insert a new set of buttons, push it back into the opening on the faceplate, and you should feel it click into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erik Thompson
31 Reputatie
5 handleidingen geschreven
UW Stout, Team 1-3, Zhou Fall 2011 Lid van UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 54
Altijd: 534
