Ga door naar hoofdinhoud
Palm m105 Batteries Replacement
  1. Palm m105 Batteries Replacement, Batteries: stap 1, afbeelding 1 van 1
    • Press the latch on the battery door on the back of the device and pull outwards.
    • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
  2. Palm m105 Batteries Replacement: stap 2, afbeelding 1 van 1
    • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
    • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
  3. Palm m105 Batteries Replacement: stap 3, afbeelding 1 van 1
    • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
Conclusie
Erik Thompson
31 Reputatie
5 handleidingen geschreven
UW Stout, Team 1-3, Zhou Fall 2011 Lid van UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Leden
7 handleidingen geschreven
2 opmerkingen
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - Antwoord
I have on that doesn't use batteries. It's a rechargeable one. Do you have any instructions on how to replace the internal battery?
deanplays - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 1,294
