Ga door naar hoofdinhoud
Palm m 100 Batteries Replacement
  1. Palm m 100 Batteries Replacement, Batteries: stap 1, afbeelding 1 van 1
    • Take the battery cover off by pushing down on the tab and lifting off.
  2. Palm m 100 Batteries Replacement: stap 2, afbeelding 1 van 1
    • Make sure batteries are there.
  3. Palm m 100 Batteries Replacement: stap 3, afbeelding 1 van 1
    • Check the type of batteries to be sure they are both AAA batteries.
    • Make sure they are installed in the right direction by taking the batteries out, aligning the positive side with the positive side and the negative side with the negative side.
  4. Palm m 100 Batteries Replacement: stap 5, afbeelding 1 van 1
    • Once positive that the batteries are installed correctly, press the on/off located at the top center of the device.
    • If the device still does not turn on, repeat the previous steps with a fresh set of AAA batteries.
Conclusie
Anne Carey
1 Reputatie
3 handleidingen geschreven
James Madison, Team 1-3, Allen Fall 2011 Lid van James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 595
