Inleiding
The Palm Zire m150 may sometimes need a motherboard replacement depending on the diagnosis. This guide will teach you how to replace that motherboard if that is the remedy needed after going through the troubleshooting steps.
Wat je nodig hebt
Lift up the flap on the Palm Zire M150.
If you wish to remove it, gently lift up and pull horizontally. It should come off without an issue.
Één andere persoon heeft deze handleiding voltooid.
