Ga door naar hoofdinhoud
Palm Zire 71 Motherboard/Screen Replacement
Wat je nodig hebt
  1. Palm Zire 71 Motherboard/Screen Replacement, Preparation: stap 1, afbeelding 1 van 1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Motherboard/Screen Replacement, Top Screws (2) Removal: stap 2, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Motherboard/Screen Replacement, Bottom Screws (3) Removal: stap 3, afbeelding 1 van 1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Motherboard/Screen Replacement, Front Panel Removal: stap 4, afbeelding 1 van 2 Palm Zire 71 Motherboard/Screen Replacement, Front Panel Removal: stap 4, afbeelding 2 van 2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Motherboard/Screen Replacement, Bracket and Speaker Removal: stap 5, afbeelding 1 van 2 Palm Zire 71 Motherboard/Screen Replacement, Bracket and Speaker Removal: stap 5, afbeelding 2 van 2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Motherboard/Screen Replacement, Back Cover: stap 6, afbeelding 1 van 2 Palm Zire 71 Motherboard/Screen Replacement, Back Cover: stap 6, afbeelding 2 van 2
    • Slide the back cover off.
  7. Palm Zire 71 Motherboard/Screen Replacement, Battery: stap 7, afbeelding 1 van 1
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Motherboard/Screen Replacement: stap 8, afbeelding 1 van 2 Palm Zire 71 Motherboard/Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Motherboard/Screen Replacement: stap 9, afbeelding 1 van 3 Palm Zire 71 Motherboard/Screen Replacement: stap 9, afbeelding 2 van 3 Palm Zire 71 Motherboard/Screen Replacement: stap 9, afbeelding 3 van 3
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Motherboard/Screen Replacement: stap 10, afbeelding 1 van 3 Palm Zire 71 Motherboard/Screen Replacement: stap 10, afbeelding 2 van 3 Palm Zire 71 Motherboard/Screen Replacement: stap 10, afbeelding 3 van 3
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
  11. Palm Zire 71 Motherboard/Screen Replacement, Motherboard/Screen: stap 11, afbeelding 1 van 2 Palm Zire 71 Motherboard/Screen Replacement, Motherboard/Screen: stap 11, afbeelding 2 van 2
    • Remove Philips screw #00
    • Remove black plastic top part
  12. Palm Zire 71 Motherboard/Screen Replacement: stap 12, afbeelding 1 van 3 Palm Zire 71 Motherboard/Screen Replacement: stap 12, afbeelding 2 van 3 Palm Zire 71 Motherboard/Screen Replacement: stap 12, afbeelding 3 van 3
    • Pull off the orange cable
    • Now the screen and the motherboard can be separated
    • Finished
Conclusie
Jinxian Jiang
245 Reputatie
3 handleidingen geschreven
CSU Los Angeles, Team 1-5, Nelson Spring 2011 Lid van CSU Los Angeles, Team 1-5, Nelson Spring 2011
CSULA-NELSON-S11S1G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 2,810
