Ga door naar hoofdinhoud
Palm Zire 31 Speaker Replacement
Wat je nodig hebt
  1. Palm Zire 31 Speaker Replacement, Case: stap 1, afbeelding 1 van 1
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Palm Zire 31 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. Palm Zire 31 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  4. Palm Zire 31 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  5. Palm Zire 31 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 1
    • The soldering iron heats up leads, wires, and everything else it touches that is metal. Leaving it on too long may damage the board or burn you.
    • Desolder the speaker wires and solder the new speaker in its place.
    • The black and red wires are connected to the two solder bulbs in the yellow box.
Conclusie
Gabe
501 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-21, Amido Winter 2011 Lid van Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 593
