Ga door naar hoofdinhoud
Palm Treo Pro Speaker Replacement
Wat je nodig hebt
  1. Palm Treo Pro Speaker Replacement, Battery: stap 1, afbeelding 1 van 3 Palm Treo Pro Speaker Replacement, Battery: stap 1, afbeelding 2 van 3 Palm Treo Pro Speaker Replacement, Battery: stap 1, afbeelding 3 van 3
    • Press down on the back of the case and slide forward to remove it.
  2. Palm Treo Pro Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by pulling up on the tab near the camera lens.
    • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
  3. Palm Treo Pro Speaker Replacement, Motherboard: stap 3, afbeelding 1 van 3 Palm Treo Pro Speaker Replacement, Motherboard: stap 3, afbeelding 2 van 3 Palm Treo Pro Speaker Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
    • Be careful not to misplace these screws as they are very small and will be important during reassembly.
    • If the screws are stripped a flat head screw driver may be necessary.
  4. Palm Treo Pro Speaker Replacement: stap 4, afbeelding 1 van 3 Palm Treo Pro Speaker Replacement: stap 4, afbeelding 2 van 3 Palm Treo Pro Speaker Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
  5. Palm Treo Pro Speaker Replacement: stap 5, afbeelding 1 van 3 Palm Treo Pro Speaker Replacement: stap 5, afbeelding 2 van 3 Palm Treo Pro Speaker Replacement: stap 5, afbeelding 3 van 3
    • Remove the main plastic body
    • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
    • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
  6. Palm Treo Pro Speaker Replacement: stap 6, afbeelding 1 van 3 Palm Treo Pro Speaker Replacement: stap 6, afbeelding 2 van 3 Palm Treo Pro Speaker Replacement: stap 6, afbeelding 3 van 3
    • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
    • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
  7. Palm Treo Pro Speaker Replacement: stap 7, afbeelding 1 van 2 Palm Treo Pro Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
  8. Palm Treo Pro Speaker Replacement: stap 8, afbeelding 1 van 3 Palm Treo Pro Speaker Replacement: stap 8, afbeelding 2 van 3 Palm Treo Pro Speaker Replacement: stap 8, afbeelding 3 van 3
    • There are two ribbon cables under the yellow tape.
    • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
    • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
  9. Palm Treo Pro Speaker Replacement: stap 9, afbeelding 1 van 3 Palm Treo Pro Speaker Replacement: stap 9, afbeelding 2 van 3 Palm Treo Pro Speaker Replacement: stap 9, afbeelding 3 van 3
    • Use a plastic opening tool to lift the motherboard up and out of the phone case
    • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
    • It can easily be disconnected with your fingers
    • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
    • The motherboard has now been completely removed
  10. Palm Treo Pro Speaker Replacement, Speaker: stap 10, afbeelding 1 van 1
    • Insert your plastic pry in the gap at the top of the phone above the speaker.
  11. Palm Treo Pro Speaker Replacement: stap 11, afbeelding 1 van 3 Palm Treo Pro Speaker Replacement: stap 11, afbeelding 2 van 3 Palm Treo Pro Speaker Replacement: stap 11, afbeelding 3 van 3
    • Gently pry the speaker until it comes out of its holder. This should not take a lot of force to do.
  12. Palm Treo Pro Speaker Replacement: stap 12, afbeelding 1 van 1
    • The speaker can be gently lifted off the phone and set aside for cleaning, repair, or replacement.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
AJ Fite
21 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-59, Johann Spring 2013 Lid van Cal Poly, Team 8-59, Johann Spring 2013
CPSU-JOHANN-S13S8G59
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 156
