Ga door naar hoofdinhoud
Palm Treo 755p Back Cover Replacement
Wat je nodig hebt
  1. Palm Treo 755p Back Cover Replacement, Battery: stap 1, afbeelding 1 van 3 Palm Treo 755p Back Cover Replacement, Battery: stap 1, afbeelding 2 van 3 Palm Treo 755p Back Cover Replacement, Battery: stap 1, afbeelding 3 van 3
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Back Cover Replacement: stap 2, afbeelding 1 van 2 Palm Treo 755p Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Back Cover Replacement, Back Cover: stap 3, afbeelding 1 van 2 Palm Treo 755p Back Cover Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
  5. Palm Treo 755p Back Cover Replacement: stap 5, afbeelding 1 van 2 Palm Treo 755p Back Cover Replacement: stap 5, afbeelding 2 van 2
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Back Cover Replacement: stap 6, afbeelding 1 van 2 Palm Treo 755p Back Cover Replacement: stap 6, afbeelding 2 van 2
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Back Cover Replacement: stap 7, afbeelding 1 van 3 Palm Treo 755p Back Cover Replacement: stap 7, afbeelding 2 van 3 Palm Treo 755p Back Cover Replacement: stap 7, afbeelding 3 van 3
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
Conclusie
Mike Shaw
601 Reputatie
6 handleidingen geschreven
Cal Poly, Team 14-6, Forte Winter 2011 Lid van Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,536
