Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press the button located just above the Sprintâ„¢ logo and then slide the cover down.
Use the small notch on the left hand side of the phone to remove the battery.
After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
Using the spudger, remove the small rubberized patch under the antenna.
Unscrew the last two screws using the same T-5 Torx screw driver.
Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
The antenna will now be loose, gently pull the antenna out of the phone.
