Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide shows how to repair a disfunctional Palm Treo 680 LCD Screen/Touch Screen.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the battery cover by pressing on the small rectangular button located on the back of the phone. Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Remove the battery by pulling it out towards you.
    • Remove the battery by pulling it out towards you.
  3. Remove the stylus in order to access the screw. Remove the 27mm top-left screw using a T6 Torx screwdriver.
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner. Remove the 27mm screw using the T6 Torx screwdriver.
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Turn the phone so the screen is facing the right side. Use a spudger to carefully separate the back panel from the front panel to access components inside the phone. Separate the covers from the left side of the device as indicated in the picture.
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Take the front the pannel and notice that the screen is attached by a piece of silver tape. Using a pair of tweezers, carefully peel off this piece of silver tape. Remove the screen from the front pannel.
    • Take the front the pannel and notice that the screen is attached by a piece of silver tape.
    • Using a pair of tweezers, carefully peel off this piece of silver tape.
    • Remove the screen from the front pannel.
  8. Obtain a small metal spudger and flip up the 2 tiny plastic flaps that hold the tiny orange ribbons in place. Do the same thing for the other flap on the opposite side.
    • Obtain a small metal spudger and flip up the 2 tiny plastic flaps that hold the tiny orange ribbons in place.
    • Do the same thing for the other flap on the opposite side.
  9. Flip the screen over a 180 degrees and take off the metal piece that cushions the screen. Flip the screen over another a 180 degrees and place pressure on the bottom ribbon (Where my left thumb is). Slightly Pull apart the touch screen from the LCD screen by placing your thumbs where my thumbs are. DO NOT PULL THE TWO SCREENS COMPLETELY APART YET.
    • Flip the screen over a 180 degrees and take off the metal piece that cushions the screen.
    • Flip the screen over another a 180 degrees and place pressure on the bottom ribbon (Where my left thumb is).
    • Slightly Pull apart the touch screen from the LCD screen by placing your thumbs where my thumbs are. DO NOT PULL THE TWO SCREENS COMPLETELY APART YET.
    • This part is tricky and might take some maneuvering and a little bit of force, but it is possible.
  10. Move your thumbs to the other corner of the screen and repeat the same procedure in step 9. Carefully peel the touch screen away from the LCD screen. Now you should have both the touch screen and LCD screen detached from one another.
    • Move your thumbs to the other corner of the screen and repeat the same procedure in step 9.
    • Carefully peel the touch screen away from the LCD screen.
    • Now you should have both the touch screen and LCD screen detached from one another.
Conclusie
Maiya123
51 Reputatie
6 handleidingen geschreven
Cal Poly, Team 6-4, Maness Fall 2009 Lid van Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Leden
12 handleidingen geschreven
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
chinthalaprasad - Antwoord
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
Ravi Joshi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 20
Altijd: 6,264
