Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will show how to separate the battery from the phone.
  1. Position the phone so the screen faces down.
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. To remove the battery cover, hold down the button in the middle of the phone's back.
    • To remove the battery cover, hold down the button in the middle of the phone's back.
    • Slide the cover down to remove. Set the cover aside.
  3. Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
Conclusie
4 andere personen hebben deze handleiding voltooid.
cgood
122 Reputatie
7 handleidingen geschreven
Cal Poly, Team 19-3, Maness Fall 2009 Lid van Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Leden
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 3,504
