Ga door naar hoofdinhoud
Palm Treo 650 Microphone Replacement
Wat je nodig hebt
  1. Palm Treo 650 Microphone Replacement, Battery and Stylus: stap 1, afbeelding 1 van 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Microphone Replacement: stap 2, afbeelding 1 van 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Microphone Replacement: stap 3, afbeelding 1 van 2 Palm Treo 650 Microphone Replacement: stap 3, afbeelding 2 van 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Microphone Replacement, Case: stap 4, afbeelding 1 van 1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Microphone Replacement: stap 5, afbeelding 1 van 2 Palm Treo 650 Microphone Replacement: stap 5, afbeelding 2 van 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Microphone Replacement: stap 6, afbeelding 1 van 1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Microphone Replacement: stap 7, afbeelding 1 van 2 Palm Treo 650 Microphone Replacement: stap 7, afbeelding 2 van 2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Microphone Replacement, Motherboard: stap 8, afbeelding 1 van 3 Palm Treo 650 Microphone Replacement, Motherboard: stap 8, afbeelding 2 van 3 Palm Treo 650 Microphone Replacement, Motherboard: stap 8, afbeelding 3 van 3
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Palm Treo 650 Microphone Replacement: stap 9, afbeelding 1 van 2 Palm Treo 650 Microphone Replacement: stap 9, afbeelding 2 van 2
    • Pull off the motherboard.
  10. Palm Treo 650 Microphone Replacement, Keyboard: stap 10, afbeelding 1 van 1
    • Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
  11. Palm Treo 650 Microphone Replacement: stap 11, afbeelding 1 van 1
    • Pull off the circuit board.
  12. Palm Treo 650 Microphone Replacement: stap 12, afbeelding 1 van 1
    • Remove the keypad for cleaning or replacing.
  13. Palm Treo 650 Microphone Replacement, Microphone: stap 13, afbeelding 1 van 1
    • Place the circuit board with the microphone facing up.
  14. Palm Treo 650 Microphone Replacement: stap 14, afbeelding 1 van 2 Palm Treo 650 Microphone Replacement: stap 14, afbeelding 2 van 2
    • Pop the microphone off with your finger.
Conclusie
cgood
122 Reputatie
7 handleidingen geschreven
Cal Poly, Team 19-3, Maness Fall 2009 Lid van Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 4,526
