Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Use the T6 Torx Screwdriver to remove all 4 screws.
Using a plastic opening tool, carefully separate the front and back cases.
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
