Inleiding
Steps to follow if you want to replace the logic board. Also needed if you want to access the camera.
Wat je nodig hebt
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
Bijna klaar!
Conclusie
