Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Turn over the device so that the back panel faces forward.
Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
Rotate the device so that the display faces forward.
Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
Pry along the crevice to loosen the back panel.
Repeat this process for the right side.
Use a plastic opening tool to peel the battery pack from the back panel.
Één andere persoon heeft deze handleiding voltooid.
