Inleiding
A guide to replace a damaged or cracked screen.
Wat je nodig hebt
Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
On the back of the screen near the top right corner is a plastic filament:
Gently lift up on the two brown clasps on either side of the filament connector as shown.
Using a thin, blunt object (a toothpick works well), slide it under the plastic filament and lift up to detach the filament from its connector.
Één andere persoon heeft deze handleiding voltooid.
