Ga door naar hoofdinhoud
Palm IIIx Motherboard Assembly Replacement
Wat je nodig hebt
  1. Palm IIIx Motherboard Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Motherboard Assembly Replacement: stap 2, afbeelding 1 van 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Motherboard Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Motherboard Assembly Replacement, Motherboard Assembly: stap 4, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Motherboard Assembly Replacement: stap 5, afbeelding 1 van 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
  6. Palm IIIx Motherboard Assembly Replacement: stap 6, afbeelding 1 van 1
    • Hold the screen and front cover on its side, facing the screen inward as shown.
    • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
  7. Palm IIIx Motherboard Assembly Replacement: stap 7, afbeelding 1 van 2 Palm IIIx Motherboard Assembly Replacement: stap 7, afbeelding 2 van 2
    • Position the device with the screen facing down.
    • Locate the white ribbon wire on the left hand side of the device.
    • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
  8. Palm IIIx Motherboard Assembly Replacement: stap 8, afbeelding 1 van 1
    • Detach the ribbon wire by gently pulling it out of its connector.
  9. Palm IIIx Motherboard Assembly Replacement: stap 9, afbeelding 1 van 1
    • Separate the motherboard from the screen.
  10. Palm IIIx Motherboard Assembly Replacement: stap 10, afbeelding 1 van 1
    • Now the motherboard assembly can be replaced successfully.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ben Johnson
22 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-43, Regan Winter 2010 Lid van Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 3,072
