Ga door naar hoofdinhoud
Inleiding
A guide to replace a damaged, lost, or broken button cluster.
  1. Place the Palm IIIx face down on a flat surface.
    • Place the Palm IIIx face down on a flat surface.
  2. Push down and lift up the battery cover to remove it.
    • Push down and lift up the battery cover to remove it.
  3. Remove the old batteries one at a time.
    • Remove the old batteries one at a time.
  4. Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Hold the device on its side, positioning your hands as shown.
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  6. Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  7. Remove cluster by pulling on the rubber backing.
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
Conclusie
David Haskell
44 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-43, Regan Winter 2010 Lid van Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Leden
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 1,198
