Inleiding
This guide show you how to remove and replace the Palm Centro's speakers
Onderdelen
Geen onderdelen nodig.
  1. Press and slide open the battery cover. Press and slide open the battery cover.
    • Press and slide open the battery cover.
  2. Caution: Turn cell phone off before removing battery!
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Phone with battery removed
    • Phone with battery removed
  4. Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Lift the rubber cap at the top right to reveal the sixth screw.
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  7. Remove the SIM card so housing can be separated. Remove the SIM card so housing can be separated.
    • Remove the SIM card so housing can be separated.
  8. Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert. Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  9. Remove the small plastic insert at the bottom of the phone. Remove the small plastic insert at the bottom of the phone.
    • Remove the small plastic insert at the bottom of the phone.
  10. Continue with plastic pry tool all the way around the phone to remove the back housing. Continue with plastic pry tool all the way around the phone to remove the back housing.
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  11. Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  12. Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  13. Separate the logic board from the case by lifting and pulling out the bottom.
    • Separate the logic board from the case by lifting and pulling out the bottom.
  14. Pry the four plastic latches free that connect the antenna to the logic board. Excessive force may damage your logic board! Remove the antenna from the logic board.
    • Pry the four plastic latches free that connect the antenna to the logic board.
    • Excessive force may damage your logic board!
    • Remove the antenna from the logic board.
  15. The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevin
31 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-49, Garner Spring 2010 Lid van Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Leden
12 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 3
Altijd: 1,406
