Ga door naar hoofdinhoud
Packard Bell 4X4 Desktop Drive Cage Replacement
Wat je nodig hebt
  1. Packard Bell 4X4 Desktop Drive Cage Replacement, Top Cover: stap 1, afbeelding 1 van 1
    • Using a Phillips screwdriver, remove the three Phillips head screws (circled in red) from the back of the computer.
  2. Packard Bell 4X4 Desktop Drive Cage Replacement: stap 2, afbeelding 1 van 1
    • With both hands on each side of the case, slide the top cover toward you. Lift it off the computer.
  3. Packard Bell 4X4 Desktop Drive Cage Replacement: stap 3, afbeelding 1 van 1
    • The top cover is removed.
  4. Packard Bell 4X4 Desktop Drive Cage Replacement, Drive Cage: stap 4, afbeelding 1 van 1
    • Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
  5. Packard Bell 4X4 Desktop Drive Cage Replacement: stap 5, afbeelding 1 van 1
    • Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
  6. Packard Bell 4X4 Desktop Drive Cage Replacement: stap 6, afbeelding 1 van 1
    • Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
  7. Packard Bell 4X4 Desktop Drive Cage Replacement: stap 7, afbeelding 1 van 1
    • Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
  8. Packard Bell 4X4 Desktop Drive Cage Replacement: stap 8, afbeelding 1 van 1
    • Lift the drive cage up and out of the computer.
Conclusie
Brandon S
490 Reputatie
3 handleidingen geschreven
Packard Bell Planet Lid van Packard Bell Planet
Community
1 Lid
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,888
