Ga door naar hoofdinhoud
Pacific Image Electronics CS3600 Motor Replacement
Wat je nodig hebt
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: stap 1, afbeelding 1 van 2 Pacific Image Electronics CS3600 Motor Replacement, Motor: stap 1, afbeelding 2 van 2
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: stap 2, afbeelding 1 van 1
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: stap 3, afbeelding 1 van 1
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: stap 4, afbeelding 1 van 2 Pacific Image Electronics CS3600 Motor Replacement: stap 4, afbeelding 2 van 2
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: stap 5, afbeelding 1 van 1
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
Conclusie
Alessia Carlton
201 Reputatie
2 handleidingen geschreven
Texas Tech, Team S46-G2, Bennett Spring 2017 Lid van Texas Tech, Team S46-G2, Bennett Spring 2017
TTU-BENNETT-S17S46G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 230
