Ga door naar hoofdinhoud
PSP Go Top Cover Replacement
Wat je nodig hebt
  1. PSP Go Top Cover Replacement, Back Cover: stap 1, afbeelding 1 van 2 PSP Go Top Cover Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
    Vraag FixBot
  2. PSP Go Top Cover Replacement: stap 2, afbeelding 1 van 2 PSP Go Top Cover Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
    Vraag FixBot
  3. PSP Go Top Cover Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Pull the top cover upwards gently from its housing.
    Vraag FixBot
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 105
Altijd: 6,857
