Ga door naar hoofdinhoud
PSP Go Display Replacement
Wat je nodig hebt
  1. PSP Go Display Replacement, Back Cover: stap 1, afbeelding 1 van 2 PSP Go Display Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
    Vraag FixBot
    Voeg opmerking toe
  2. PSP Go Display Replacement: stap 2, afbeelding 1 van 2 PSP Go Display Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
    Vraag FixBot
    Voeg opmerking toe
  3. PSP Go Display Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Pull the top cover upwards gently from its housing.
    Vraag FixBot
    Voeg opmerking toe
  4. PSP Go Display Replacement, Left Trigger: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to gently flip up the left trigger connector.
    Vraag FixBot
    Voeg opmerking toe
  5. PSP Go Display Replacement: stap 5, afbeelding 1 van 2 PSP Go Display Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
    Vraag FixBot
    Voeg opmerking toe
  6. PSP Go Display Replacement, Battery: stap 6, afbeelding 1 van 3 PSP Go Display Replacement, Battery: stap 6, afbeelding 2 van 3 PSP Go Display Replacement, Battery: stap 6, afbeelding 3 van 3
    • Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
    • Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
    Vraag FixBot
    Voeg opmerking toe
  7. PSP Go Display Replacement: stap 7, afbeelding 1 van 1
    • Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
    • Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
    • Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
    Vraag FixBot
    Voeg opmerking toe
  8. PSP Go Display Replacement: stap 8, afbeelding 1 van 2 PSP Go Display Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to pop out the battery, being careful not to snag the "Warranty Void" sticker in the process.
    • When putting a new battery into the PSP Go, make sure you hold the "Warranty Sticker" so you don't put the battery on top of it.
    Vraag FixBot
    Voeg opmerking toe
  9. PSP Go Display Replacement, Logic Board: stap 9, afbeelding 1 van 1
    • Remove the single Phillips screw securing the logic board to the inner case.
    Vraag FixBot
    Voeg opmerking toe
  10. PSP Go Display Replacement: stap 10, afbeelding 1 van 2 PSP Go Display Replacement: stap 10, afbeelding 2 van 2
    • Use a plastic opening tool to gently flip up the right trigger connector.
    Vraag FixBot
    Voeg opmerking toe
  11. PSP Go Display Replacement: stap 11, afbeelding 1 van 2 PSP Go Display Replacement: stap 11, afbeelding 2 van 2
    • Use a #00 Phillips screwdriver to unscrew both bottom plate screws.
    • Remove the bottom plate by lifting it away from the device.
    Vraag FixBot
    Voeg opmerking toe
  12. PSP Go Display Replacement: stap 12, afbeelding 1 van 1
    • Remove both headphone jack and analog joystick screws using your #00 Phillips screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  13. PSP Go Display Replacement: stap 13, afbeelding 1 van 2 PSP Go Display Replacement: stap 13, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Be very careful when disconnecting the following cables. The connectors do not have flip-up tabs; just hold each cable steady and pull it out of the connector.
    • Unplug the volume button cable using a pair of tweezers. Be careful not to damage the cable.
    • Unplug the Start/Select button cable the same way. Make sure to grasp the black plastic pull tab of the cable.
    Vraag FixBot
    Voeg opmerking toe
  14. PSP Go Display Replacement: stap 14, afbeelding 1 van 1
    • Use a pair of tweezers to pull out the battery's clear plastic cover.
    • Notice the little metal tab and slot (marked in red) where the clear plastic cover slides into. Make sure you slide the cover into place properly when reassembling the PSP Go.
    Vraag FixBot
    Voeg opmerking toe
  15. PSP Go Display Replacement: stap 15, afbeelding 1 van 1
    • The logic board is still connected to the display, so do not fully remove it from its housing!
    • Gently lift the logic board slightly out of its housing.
    Vraag FixBot
    Voeg opmerking toe
  16. PSP Go Display Replacement: stap 16, afbeelding 1 van 2 PSP Go Display Replacement: stap 16, afbeelding 2 van 2
    • Use a plastic opening tool to disconnect the display cable from the logic board.
    • The D-pad may come loose while prying the logic board.
    • The logic board should now be free from the rest of the device.
    • During reassembly, make sure to properly line up the power button with the power button lever on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  17. PSP Go Display Replacement, Display: stap 17, afbeelding 1 van 1
    • Use a #00 Phillips screwdriver to remove the four display screws.
    Vraag FixBot
    Voeg opmerking toe
  18. PSP Go Display Replacement: stap 18, afbeelding 1 van 3 PSP Go Display Replacement: stap 18, afbeelding 2 van 3 PSP Go Display Replacement: stap 18, afbeelding 3 van 3
    • Wedge a plastic opening tool in the location shown in the first picture, and slightly separate the metal frame from the plastic front panel.
    • Slide the plastic opening tool around the perimeter of the display, increasing the gap between the metal frame and the front panel.
    • The front panel should now be free from the metal frame. However, it is still connected to the frame, so don't remove it completely.
    Vraag FixBot
    Voeg opmerking toe
  19. PSP Go Display Replacement: stap 19, afbeelding 1 van 2 PSP Go Display Replacement: stap 19, afbeelding 2 van 2
    • Use a plastic opening tool to disconnect the display cable from the rest of the device.
    • The PSP Go should now look similar to the second picture.
    Vraag FixBot
    Voeg opmerking toe
  20. PSP Go Display Replacement: stap 20, afbeelding 1 van 2 PSP Go Display Replacement: stap 20, afbeelding 2 van 2
    • Be very careful when performing this procedure! If you put too much pressure on the display, you risk cracking it.
    • Wedge a plastic opening tool between the plastic front panel and display. Be very careful that you wedge it in the same location shown in the first picture.
    • Slide the plastic opening tool across the length of the display. This should loosen the glue binding the display to the plastic front panel.
    • Rotate the display 180 degrees and free the bottom side of the display in the same manner.
    Vraag FixBot
    Voeg opmerking toe
  21. PSP Go Display Replacement: stap 21, afbeelding 1 van 1
    • Gently separate the display from the front panel.
    • Match the orientation of the PSP logo on the display with the Sony logo on the front panel when reassembling the PSP Go.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
30 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
Omg seriously!,,, Took this Dental Hygienist exactly one hour to do this! Awesome ! Thank you!
cyndiecote2006 - Antwoord Deel
My psp won't turn back on please help I followed the directions exactly.
Daniel martinez - Antwoord Deel
I use this guides to perform a flexible replacement because the original one is just too old and it's snapped some how, I've done it and my PSP Go work normal as before but I did make a mistake. I cracked the display. Yes it is really, really, really fragile! When he said “be very gentle/careful” he really mean it.
Learn from my mistakes, but I will fix it. Again.
HaKoSuKa GTR - Antwoord Deel
Fantastic guide! I’ve been meaning to deep clean and replace the screen for an old PSP Go that a friend gave to me. The original screen had a few deep scratches, and the console itself was grimey from food or fizzy drink. Anyways super fresh now, and this guide was perfect!
LieinKing - Antwoord Deel
I did it without the guide (I worked on my PSP Go before so I knew how to do it just based on my experience tearing it down and putting it back together) and now my PSP Go won't boot up.
Wflash00 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 106
Afgelopen 30 dagen: 440
Altijd: 67,787
