Inleiding
Use this guide to remove the PSP Go's directional pad buttons.
Wat je nodig hebt
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Use a plastic opening tool to gently flip up the left trigger connector.
Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
Remove the single Phillips screw securing the logic board to the inner case.
Use a plastic opening tool to take out the directional pad buttons.
3 andere personen hebben deze handleiding voltooid.
