Ga door naar hoofdinhoud
PSP E1000 Battery Replacement
Wat je nodig hebt
  1. PSP E1000 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 PSP E1000 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • To start the replacement flip the device over
  2. PSP E1000 Battery Replacement: stap 2, afbeelding 1 van 2 PSP E1000 Battery Replacement: stap 2, afbeelding 2 van 2
    • We are going to start by removing the back panel.
    • To do this open the panel and gently squeeze in the UMD tray until it pops up.
    • It should lay flat against the back panel while open if done correctly
  3. PSP E1000 Battery Replacement: stap 3, afbeelding 1 van 2 PSP E1000 Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently bend the back panel to free the hinge on the left.
    • Once it is popped out it should look like the second photo
    • The back panel can then be slid off
  4. PSP E1000 Battery Replacement: stap 5, afbeelding 1 van 3 PSP E1000 Battery Replacement: stap 5, afbeelding 2 van 3 PSP E1000 Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the screw with a #00 Philips and slide up the battery cover.
    • The battery can now be removed by pulling it out.
    • When reinstalling, it is useful to use a spudger to push the cable back in.
    • Congratulations you have replaced your PSP E1000's battery
Conclusie
Caleb Pierce
554 Reputatie
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 66
Afgelopen 30 dagen: 172
Altijd: 172
