Ga door naar hoofdinhoud
PSP 300xc Home Bar Replacement
Wat je nodig hebt
  1. PSP 300xc Home Bar Replacement, Battery: stap 1, afbeelding 1 van 2 PSP 300xc Home Bar Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc Home Bar Replacement, Front Case: stap 2, afbeelding 1 van 1
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc Home Bar Replacement: stap 3, afbeelding 1 van 2 PSP 300xc Home Bar Replacement: stap 3, afbeelding 2 van 2
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc Home Bar Replacement: stap 4, afbeelding 1 van 1
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc Home Bar Replacement: stap 5, afbeelding 1 van 1
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc Home Bar Replacement: stap 6, afbeelding 1 van 2 PSP 300xc Home Bar Replacement: stap 6, afbeelding 2 van 2
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc Home Bar Replacement, LCD: stap 7, afbeelding 1 van 1
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc Home Bar Replacement: stap 8, afbeelding 1 van 2 PSP 300xc Home Bar Replacement: stap 8, afbeelding 2 van 2
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc Home Bar Replacement: stap 9, afbeelding 1 van 1
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc Home Bar Replacement: stap 10, afbeelding 1 van 1
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc Home Bar Replacement: stap 11, afbeelding 1 van 3 PSP 300xc Home Bar Replacement: stap 11, afbeelding 2 van 3 PSP 300xc Home Bar Replacement: stap 11, afbeelding 3 van 3
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc Home Bar Replacement: stap 12, afbeelding 1 van 1
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc Home Bar Replacement, Home Bar: stap 13, afbeelding 1 van 3 PSP 300xc Home Bar Replacement, Home Bar: stap 13, afbeelding 2 van 3 PSP 300xc Home Bar Replacement, Home Bar: stap 13, afbeelding 3 van 3
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Newsom
39.500 Reputatie
67 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 4,341
