Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Steps for removing the motherboard of a Sony PSP-3000
Wat je nodig hebt
Place the PSP face down and locate the battery cover on the left side of the device.
Lift and remove the battery cover to reveal the battery.
Remove the battery.
Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
Push the homebar to the right to release the tab located on the right side of the LCD screen.
The speaker is spring loaded, so be sure to keep an eye on it in case it starts doing flips into the air when you push the tab. Be careful not to lose or damage it!
Remove the screw from the top of the power switch panel. Gently remove panel from pegs starting from switch side.
15 andere personen hebben deze handleiding voltooid.
