Ga door naar hoofdinhoud
PSP 300x LCD Screen Replacement
Wat je nodig hebt
  1. PSP 300x LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 3 PSP 300x LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 3 PSP 300x LCD Screen Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x LCD Screen Replacement, Front Casing: stap 2, afbeelding 1 van 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x LCD Screen Replacement: stap 3, afbeelding 1 van 2 PSP 300x LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x LCD Screen Replacement: stap 6, afbeelding 1 van 2 PSP 300x LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x LCD Screen Replacement, LCD Screen: stap 7, afbeelding 1 van 2 PSP 300x LCD Screen Replacement, LCD Screen: stap 7, afbeelding 2 van 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
  8. PSP 300x LCD Screen Replacement: stap 8, afbeelding 1 van 3 PSP 300x LCD Screen Replacement: stap 8, afbeelding 2 van 3 PSP 300x LCD Screen Replacement: stap 8, afbeelding 3 van 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
  9. PSP 300x LCD Screen Replacement: stap 9, afbeelding 1 van 2 PSP 300x LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
  10. PSP 300x LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
Conclusie
53 andere personen hebben deze handleiding voltooid.
mbnewsom
3.439 Reputatie
11 handleidingen geschreven
1Gids Commentaar
Y como quito los tornillos de la parte superior de la psp que están barridos?
Said Hernández - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 43
Afgelopen 7 dagen: 340
Afgelopen 30 dagen: 1,563
Altijd: 114,782
