Ga door naar hoofdinhoud
PSP 300x Casing Replacement
Wat je nodig hebt
  1. PSP 300x Casing Replacement, Battery: stap 1, afbeelding 1 van 3 PSP 300x Casing Replacement, Battery: stap 1, afbeelding 2 van 3 PSP 300x Casing Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Casing Replacement, Casing: stap 2, afbeelding 1 van 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Casing Replacement: stap 3, afbeelding 1 van 2 PSP 300x Casing Replacement: stap 3, afbeelding 2 van 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Casing Replacement: stap 4, afbeelding 1 van 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Casing Replacement: stap 5, afbeelding 1 van 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Casing Replacement: stap 6, afbeelding 1 van 2 PSP 300x Casing Replacement: stap 6, afbeelding 2 van 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
Conclusie
25 andere personen hebben deze handleiding voltooid.
kbrunner
72 Reputatie
1 Handleiding geschreven
Cal Poly, Team 19-2, Maness Fall 2009 Lid van Cal Poly, Team 19-2, Maness Fall 2009
CPSU-MANESS-F09S19G2
3 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 57
Afgelopen 30 dagen: 280
Altijd: 16,140
