Ga door naar hoofdinhoud
PSP 2000 Speaker Replacement
Wat je nodig hebt
  1. PSP 2000 Speaker Replacement, Battery: stap 1, afbeelding 1 van 3 PSP 2000 Speaker Replacement, Battery: stap 1, afbeelding 2 van 3 PSP 2000 Speaker Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Speaker Replacement, Front Casing: stap 2, afbeelding 1 van 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Speaker Replacement: stap 3, afbeelding 1 van 2 PSP 2000 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Speaker Replacement: stap 4, afbeelding 1 van 2 PSP 2000 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
    Mighty Sashiman - Antwoord
  5. PSP 2000 Speaker Replacement: stap 5, afbeelding 1 van 2 PSP 2000 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  6. PSP 2000 Speaker Replacement, Display: stap 6, afbeelding 1 van 3 PSP 2000 Speaker Replacement, Display: stap 6, afbeelding 2 van 3 PSP 2000 Speaker Replacement, Display: stap 6, afbeelding 3 van 3
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
  7. PSP 2000 Speaker Replacement: stap 7, afbeelding 1 van 3 PSP 2000 Speaker Replacement: stap 7, afbeelding 2 van 3 PSP 2000 Speaker Replacement: stap 7, afbeelding 3 van 3
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
    There are 2 ribbons connected to the screen. Both of them have to be disconnected in order to remove the screen.
    Ovismue Veholkin - Antwoord
  8. PSP 2000 Speaker Replacement, Speaker: stap 8, afbeelding 1 van 2 PSP 2000 Speaker Replacement, Speaker: stap 8, afbeelding 2 van 2
    • Use the opening tools to press the tab on the left-hand side of the speaker to release it.
    • Be careful not to puncture the speaker in the process.
    • Remove the speaker by twisting it counter-clockwise (to the left, like a screw).
Conclusie
espinks
3.472 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-3, Maness Fall 2009 Lid van Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Leden
35 handleidingen geschreven
Één opmerking
What about the other speaker? How to replace?
felipeavatar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 68
Altijd: 12,398
