Ga door naar hoofdinhoud
PSP 2000 Front Casing Replacement
Wat je nodig hebt
  1. PSP 2000 Front Casing Replacement, Battery: stap 1, afbeelding 1 van 3 PSP 2000 Front Casing Replacement, Battery: stap 1, afbeelding 2 van 3 PSP 2000 Front Casing Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Front Casing Replacement, Front Casing: stap 2, afbeelding 1 van 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Front Casing Replacement: stap 3, afbeelding 1 van 2 PSP 2000 Front Casing Replacement: stap 3, afbeelding 2 van 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Front Casing Replacement: stap 4, afbeelding 1 van 2 PSP 2000 Front Casing Replacement: stap 4, afbeelding 2 van 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
  5. PSP 2000 Front Casing Replacement: stap 5, afbeelding 1 van 2 PSP 2000 Front Casing Replacement: stap 5, afbeelding 2 van 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
Conclusie
17 andere personen hebben deze handleiding voltooid.
pepe32290
1.768 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-3, Maness Fall 2009 Lid van Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Leden
48 handleidingen geschreven
2Gids Commentaar
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - Antwoord Deel
sorry this is a decade too late HA. i just did a swap for the plastic screen cover and yes, for anyone in the future, the plastic cover is on the front shell piece, you will need some tweezers or something narrow to get the plastic screen popped off, dont crack the front shell, the bottom gets fragile so just be slow and methodical. but its an easy swap, maybe 15 minutes. good time to clear out the lint around the joystick as well.
Scott Munier - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 353
Altijd: 31,866
