Inleiding
Cracked/broken LCD? No problem! Replace it with ease.
Wat je nodig hebt
Place PSP face down, so that the UMD Drive is facing upwards.
Locate the battery door and open.
Remove the battery from inside.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Remove the following screws from around the bezel:
Two 4 mm Phillips
One 5 mm Phillips
Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
With the home bar out of the way, gently pry up the display using the opening tools.
Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
Gently lift out the display.
There are 2 ribbons connected to the screen. Both of them have to be disconnected in order to remove the screen.
60 andere personen hebben deze handleiding voltooid.
5 opmerkingen
That does’t seem that hard. Is this tutorial working with the PSP2004?
Yes it is, just did it :)
Billy -
I was wondering why after replacing the screen that the new one only shows a blank black screen. The backlight turns on and it plays the boot up sequence and you can play around on the Home Screen, but you just cant see what you’re doing on the screen. Everything seems connected right. Any suggestions??
