Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Cracked/broken LCD? No problem! Replace it with ease.
  1. Place PSP face down, so that the UMD Drive is facing upwards. Locate the battery door and open. Remove the battery from inside.
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. This step requires the removal of the warranty sticker. Removing the sticker will void the warranty.  According to the FTC removing this will not void your warranty.
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. Remove four 5 mm Phillips from the case. If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Remove the following screws from around the bezel: Two 4 mm Phillips
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
    Mighty Sashiman - Antwoord
  6. Gently pry the front bezel away from the casing using a PSP opening tool. Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  7. Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device. A ribbon cable connects the home bar to the logic board.  Be careful not to damage the cable when removing the bar. A ribbon cable connects the home bar to the logic board.  Be careful not to damage the cable when removing the bar.
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
  8. With the home bar out of the way, gently pry up the display using the opening tools. There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing. Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
Conclusie
48 andere personen hebben deze handleiding voltooid.
espinks
3.017 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-3, Maness Fall 2009 Lid van Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Leden
29 handleidingen geschreven
That does’t seem that hard. Is this tutorial working with the PSP2004?
Jack Galinski - Antwoord
Yes it is, just did it :)
Billy -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 77
Afgelopen 30 dagen: 294
Altijd: 47,301
