Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place PSP face down, so that the UMD Drive is facing upwards.
Locate the battery door and open.
Remove the battery from inside.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Remove the following screws from around the bezel:
Two 4 mm Phillips
One 5 mm Phillips
Gently pry the front bezel away from the casing using a PSP opening tool.
Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
With the home bar out of the way, gently pry up the display using the opening tools.
Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
Gently lift out the display.
Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
Slide off the left trigger along with the plastic bracket underneath.
Carefully pry off left trigger button using opening tools.
Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
Gently remove the memory card slot by pulling it straight out.
15 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Thank you, i'am Zakaria Farid from Morocoo
would this work for a 2001 model?
