Ga door naar hoofdinhoud
PSP 1000 Speakers Replacement
Wat je nodig hebt
  1. PSP 1000 Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Speakers Replacement: stap 2, afbeelding 1 van 2 PSP 1000 Speakers Replacement: stap 2, afbeelding 2 van 2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 Speakers Replacement: stap 3, afbeelding 1 van 2 PSP 1000 Speakers Replacement: stap 3, afbeelding 2 van 2
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 Speakers Replacement, Front Casing: stap 4, afbeelding 1 van 2 PSP 1000 Speakers Replacement, Front Casing: stap 4, afbeelding 2 van 2
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Speakers Replacement: stap 6, afbeelding 1 van 2 PSP 1000 Speakers Replacement: stap 6, afbeelding 2 van 2
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 Speakers Replacement, LCD Screen: stap 7, afbeelding 1 van 1
    • The Button Board, at the base of the LCD Screen, is held by two clips.
    • Pry these clips over the nubs using a PSP opening tool. This will release the clips.
    • The Button Board is still attatched to the PSP by a ribbon cable!
  8. PSP 1000 Speakers Replacement: stap 8, afbeelding 1 van 3 PSP 1000 Speakers Replacement: stap 8, afbeelding 2 van 3 PSP 1000 Speakers Replacement: stap 8, afbeelding 3 van 3
    • The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch.
  9. PSP 1000 Speakers Replacement: stap 9, afbeelding 1 van 2 PSP 1000 Speakers Replacement: stap 9, afbeelding 2 van 2
    • The LCD Screen is held by the LCD Frame with similar clips. Slide a thin tool between the clip and the screen and gently pry them apart while beginning to lift the screen.
  10. PSP 1000 Speakers Replacement: stap 10, afbeelding 1 van 1
    • The LCD screen is still attached with ribbon cables. Gently lift up the LCD screen so you do not break them.
  11. PSP 1000 Speakers Replacement: stap 11, afbeelding 1 van 3 PSP 1000 Speakers Replacement: stap 11, afbeelding 2 van 3 PSP 1000 Speakers Replacement: stap 11, afbeelding 3 van 3
    • The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
    • The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
    • Both of these latches are the black pieces.
    • Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
    • When reassembling - be careful which way you push the latches. The small one is very easy to break.
  12. PSP 1000 Speakers Replacement, Speakers: stap 12, afbeelding 1 van 1
    • Remove the screws on the top and bottom of the frame. Be sure to keep track of where you took each screw out of.
  13. PSP 1000 Speakers Replacement: stap 13, afbeelding 1 van 1
    • After the screws are removed, the bottom of the LCD frame will rise.
    • Open up the UMD Drive, and then slide the top of the LCD frame slightly to the right while pulling out.
  14. PSP 1000 Speakers Replacement: stap 14, afbeelding 1 van 1
    • The speakers will now be exposed.
  15. PSP 1000 Speakers Replacement: stap 15, afbeelding 1 van 2 PSP 1000 Speakers Replacement: stap 15, afbeelding 2 van 2
    • The speakers should slide out fairly easily; it may be helpful to use tweezers to begin prying them out.
  16. PSP 1000 Speakers Replacement: stap 16, afbeelding 1 van 3 PSP 1000 Speakers Replacement: stap 16, afbeelding 2 van 3 PSP 1000 Speakers Replacement: stap 16, afbeelding 3 van 3
    • Gently unplug the speakers from the socket. The speakers are completely detatched when they are unplugged from the logic board.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Chris
1.913 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-6, Forte Winter 2010 Lid van Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 116
Altijd: 23,803
