Inleiding
This guide will help you replace the LCD screen if it has been cracked or damaged.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
The Button Board, at the base of the LCD Screen, is held by two clips.
Pry these clips over the nubs using a PSP opening tool. This will release the clips.
The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
Both of these latches are the black pieces.
Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
61 andere personen hebben deze handleiding voltooid.
7 Opmerkingen
This is not easy...I tore up the outer casing trying to do this. I better see money in the mail for this
People!! If you weren't gifted in screws and bolts, then bring your console to a repair shop. Seriously blaming this for your Dick Fingers?
dick fingers!!
