Ga door naar hoofdinhoud
PSP 1000 Buttons Replacement
Wat je nodig hebt
  1. PSP 1000 Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Buttons Replacement: stap 2, afbeelding 1 van 2 PSP 1000 Buttons Replacement: stap 2, afbeelding 2 van 2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
    You are dumbbb... BRO YOUR DUMB BC U DIDNT HAVE TO USE A TOOL TO OPEN THE DOOR. USE YOUR FINGER""
    Paulo Moments - Antwoord
    The battery door can be damaged dont use a tool
    That also happend to me it got destroyed by screwdriver
  3. PSP 1000 Buttons Replacement: stap 3, afbeelding 1 van 2 PSP 1000 Buttons Replacement: stap 3, afbeelding 2 van 2
    • Using your finger, remove the battery upwards from the system as shown.
    The use of the opening tool is completely unnecessary. There is a finger actuated opening latch button that says “PUSH” on it. Simply press down with your thumb then slide your thumb down and away, dragining the battery door with it. It will then come off. Assuming the system still has its original plastics, they may have become brittle enough that the opening tool could damage the release button or the plastic cover.
    Franklin Allen - Antwoord
  4. PSP 1000 Buttons Replacement, Front Casing: stap 4, afbeelding 1 van 2 PSP 1000 Buttons Replacement, Front Casing: stap 4, afbeelding 2 van 2
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
    Much luck to you if you have a tiny, metal screwdriver like I did, the screws might be stuck in there and may require some force.
    Squib - Antwoord
    you need to peel back the warranty sticker in order to access both the lower left and lower left screws
    Frederick zzstu Geib - Antwoord
    This is a bit misleading, you should only remove the two black screws in the battery compartment. The silver ones can stay.
    Damian Cartwright - Antwoord
    The two left hand screws won’t come out of mine
    XULF - Antwoord
    iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot.
    Fliggle_Slaps - Antwoord
    Can't edit previous comment so here's a new one:
    Standard or older iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot. You'll need precision bits that have longer tips to reach these deep screws.
  5. PSP 1000 Buttons Replacement: stap 5, afbeelding 1 van 1
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Buttons Replacement: stap 6, afbeelding 1 van 2 PSP 1000 Buttons Replacement: stap 6, afbeelding 2 van 2
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 Buttons Replacement, Buttons: stap 7, afbeelding 1 van 3 PSP 1000 Buttons Replacement, Buttons: stap 7, afbeelding 2 van 3 PSP 1000 Buttons Replacement, Buttons: stap 7, afbeelding 3 van 3
    • If the Arrow Buttons are not functioning properly, flip over the outer casing and locate the inside of the buttons, as shown
    • Carefully remove the black rubber backing off of the buttons.
    • Clean the inside of the rubber and the outside of the buttons with a cloth.
  8. PSP 1000 Buttons Replacement: stap 8, afbeelding 1 van 2 PSP 1000 Buttons Replacement: stap 8, afbeelding 2 van 2
    • If needed, replace the old buttons with a new set (which can be purchased from Sony or other electronics stores).
    • Carefully re-insert the buttons. This should not require excess force, as the buttons should fit if they are arranged correctly.
    • Gently re-apply the back rubber to the back of the buttons.
  9. PSP 1000 Buttons Replacement: stap 9, afbeelding 1 van 2 PSP 1000 Buttons Replacement: stap 9, afbeelding 2 van 2
    • If function buttons (x, square, circle, triangle) need to be replaced, find the corresponding black rubber backing on the inside of the casing.
    • Carefully remove the back rubber to expose the rear side of the buttons as shown. (This can be done using your hands.)
  10. PSP 1000 Buttons Replacement: stap 10, afbeelding 1 van 2 PSP 1000 Buttons Replacement: stap 10, afbeelding 2 van 2
    • Next, carefully clean the receiving end of the buttons on the motherboard (shown on picture) with a cloth.
    • If the buttons are clearly damaged, then they need to be replaced.
    • Add the new ones in the form, with the correct button order. (The correct button order has the Triangle on the top, Square on the right, Circle on the left, and X on the bottom).
    • Be very careful! The buttons only go in one way. If you have trouble fitting them in, rotate them in their given spots until they fit in easily. Do NOT force them. Forcing the buttons in may cause damage.
  11. PSP 1000 Buttons Replacement: stap 11, afbeelding 1 van 1
    • Once buttons are correctly replaced, the back rubbers are fit back onto the buttons, refer back to Replacing the Housing to reattach the casing.
Conclusie
32 andere personen hebben deze handleiding voltooid.
Henry Lee
794 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-6, Forte Winter 2010 Lid van Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Leden
22 handleidingen geschreven
12 opmerkingen
It's a helpful guide,thx
Zero Knight - Antwoord
Great guide. I highly Recomend this to anyone that needs to replace their PSP buttons
unashamed45 - Antwoord
Otimo guia recomendo.
richardmosman - Antwoord
use magnetised screwdriver i had a normal one and it was a pain in the ass to put those tiny little bastards back
Nagy Dániel - Antwoord
Thank you this was a great guide
BLAISE of BASH - Antwoord
I have a similar problem with my psp 3000. The X button does not work when it is pressed. I removed the casing, checked if there was dirt on the rubber padding and on the motherboard where the buttons sit and there is no dirt. What should I do now. I realy love my psp, but without the X button working I can not use it. Is this problem fixable?
Christopher - Antwoord
Christopher, if that’s the case then you probably need to replace the conductive rubber padding, as that’s the part that really gets all the wear. I don’t know where you would find a replacement rubber padding, but you might try eBay or Amazon.
Daniel Whalen - Antwoord
Hey Daniel, thanks for your responce. Im still not sure exactly what the probelm is myself so thanks for the insight. I have ordered a new flex cable to see if that’s the soultion. Could this be the problem, a broken flex cables?
I recently bought a psp 3000 and when I started to use it, in the software of the psp the “X” button is set as the back button and the “O” button is set to be the enter button. I reset the factory setting, it doesn’t go to “X” being enter and “O” being back. Anyone know how to fix this problem? Could the psp be fake?
Blank Blank - Antwoord
It must be the Japanese Model. I own two Japanese psps and O is always the enter button. X is the back button and triangle is usually the menu screen. Hope that helps!
Pickle Satan -
My issues is the joy stick and it doesn't show how to fix joystick
Freezing God - Antwoord
Como solucionar quando o aparelho começa a entrar sozinho para sair do jogo ?
Ale Xandão - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 99
Afgelopen 30 dagen: 476
Altijd: 82,236
