Ga door naar hoofdinhoud
PS4 Dualshock 4 trigger reassembly
Wat je nodig hebt
  1. PS4 Dualshock 4 trigger reassembly, Preparing the triggers: stap 1, afbeelding 1 van 2 PS4 Dualshock 4 trigger reassembly, Preparing the triggers: stap 1, afbeelding 2 van 2
    • Remove these two triggers and springs from the backplate.
    • Find which trigger goes on which side and put the springs in the trigger part facing towards the inside of the controller.
  2. PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: stap 2, afbeelding 1 van 2 PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: stap 2, afbeelding 2 van 2
    • On these two clips...
    • Push down the trigger until it clicks on both sides.
    • Make sure that the one spring part is inside the rail (marked cyan) and the other outside the whole assembly (green).
  3. PS4 Dualshock 4 trigger reassembly, Connecting the light bar: stap 3, afbeelding 1 van 1
    • Connect the light bar cable using your fingers. Make sure it is fully pushed down and that is plugged in the right way.
  4. PS4 Dualshock 4 trigger reassembly, Closing the cover: stap 4, afbeelding 1 van 2 PS4 Dualshock 4 trigger reassembly, Closing the cover: stap 4, afbeelding 2 van 2
    • close the cover starting from the side of the triggers. Don't worry if it's a bit hard to do so, but be careful so you don't break the plastic between the trigger and the bumper.
    • Push down until it clicks everywhere.
    • Finally, screw in these four screws using a PH0 screwdriver.
Eindstreep
24 andere personen hebben deze handleiding voltooid.
Devnol
2.798 Reputatie
5 handleidingen geschreven
3 opmerkingen
Thank you so much! I had a ps4 controller that had a broken r2 button and i had gotten a replacement (which is now having battery issues) Today I took the old controller apart… the spring had come out of the rail. That was it!
Dee - Antwoord
This guide is wrong. The top part spring should be inside the trigger, if you look at the other trigger it’s not exposed.
https://pureplaystation.com/wp-content/u...
Angus Yung - Antwoord
Thanks for pointing it out. I do not have this controller anymore as it was from a repair job so unfortunately, I cannot correct it. If you or someone else happens to have one and is able to take high-quality pictures I’d be more than grateful to accept your correction.
Devnol -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 99
Afgelopen 30 dagen: 378
Altijd: 45,113
