Ga door naar hoofdinhoud
PS Vita Slim Joystick Replacement
Wat je nodig hebt
  1. PS Vita Slim Joystick Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
  2. PS Vita Slim Joystick Replacement: stap 2, afbeelding 1 van 2 PS Vita Slim Joystick Replacement: stap 2, afbeelding 2 van 2
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
  3. PS Vita Slim Joystick Replacement: stap 3, afbeelding 1 van 3 PS Vita Slim Joystick Replacement: stap 3, afbeelding 2 van 3 PS Vita Slim Joystick Replacement: stap 3, afbeelding 3 van 3
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
  4. PS Vita Slim Joystick Replacement: stap 4, afbeelding 1 van 1
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
  5. PS Vita Slim Joystick Replacement, Joystick: stap 5, afbeelding 1 van 3 PS Vita Slim Joystick Replacement, Joystick: stap 5, afbeelding 2 van 3 PS Vita Slim Joystick Replacement, Joystick: stap 5, afbeelding 3 van 3
    • Starting with the left joystick.
    • There is a green casing holding in the joystick it will need to be removed to allow access .
    • There are 3 ribbons holding the section together. Remove them carefully.
    • Next unscrew the two screws holding down the casing. They will both still be 6.35 mm screws and will be able to be taken out by a J00 bit from the iFixit pro toolkit.
    • Now carefully left the metal piece holding down the green casing, it will be the last resistance. Lift out the green casing now.
  6. PS Vita Slim Joystick Replacement: stap 6, afbeelding 1 van 2 PS Vita Slim Joystick Replacement: stap 6, afbeelding 2 van 2
    • Once the casing has been removed there will be one more screw to be removed. It will be a 6.35 mm screws that requires a J00 screwdriver from the iFixit pro toolkit.
    • Now simply and carefully take out the joystick out.
    • With the joystick taken out you can now do what is needed on the left joystick, or even replace it.
  7. PS Vita Slim Joystick Replacement: stap 7, afbeelding 1 van 3 PS Vita Slim Joystick Replacement: stap 7, afbeelding 2 van 3 PS Vita Slim Joystick Replacement: stap 7, afbeelding 3 van 3
    • Switching over to the right joystick.
    • There will be a green casing containing the joystick. First it must be removed.
    • Carefully remove the ribbons from the entire section.
    • Proceed to remove the two screws holding the casing down. They will be 6.35 mm screws and can be removed using a J00 bit.
  8. PS Vita Slim Joystick Replacement: stap 8, afbeelding 1 van 3 PS Vita Slim Joystick Replacement: stap 8, afbeelding 2 van 3 PS Vita Slim Joystick Replacement: stap 8, afbeelding 3 van 3
    • Once the casing is off, there will only be one more screw to take off. It will also be a 6.35 mm screw that uses the J00 bit from the iFixit pro toolkit.
    • Now simply remove the joystick from the device .
    • Once the joystick is removed you can do what is needed to the right joystick part, or even replace it if needed.
Conclusie
41 andere personen hebben deze handleiding voltooid.
Daniel Woodard
2.991 Reputatie
7 handleidingen geschreven
17 opmerkingen
Would I have a problem if I used 2 screws for the right analog stick , it solved my ghost movement
Art Front - Antwoord
I have changed the analog stick, but it is still not working
akash shah - Antwoord
Can you switch left with right analog stick?
Pyro Haze - Antwoord
yes you can switch them. but its recommended to get a pair of new analog sticks so you dont have to open it again when the other side fails
Darian Perisic -
Fixed, very easy! Thanks a lot
Julien Lemoine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 153
Afgelopen 30 dagen: 794
Altijd: 37,829
