Ga door naar hoofdinhoud
PS Vita Slim Battery Replacement
Wat je nodig hebt
  1. PS Vita Slim Battery  Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
  2. PS Vita Slim Battery  Replacement: stap 2, afbeelding 1 van 2 PS Vita Slim Battery  Replacement: stap 2, afbeelding 2 van 2
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
  3. PS Vita Slim Battery  Replacement: stap 3, afbeelding 1 van 3 PS Vita Slim Battery  Replacement: stap 3, afbeelding 2 van 3 PS Vita Slim Battery  Replacement: stap 3, afbeelding 3 van 3
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
  4. PS Vita Slim Battery  Replacement: stap 4, afbeelding 1 van 1
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
  5. PS Vita Slim Battery  Replacement, Battery: stap 5, afbeelding 1 van 3 PS Vita Slim Battery  Replacement, Battery: stap 5, afbeelding 2 van 3 PS Vita Slim Battery  Replacement, Battery: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Spudger
    $3.99
    • The battery should be very visible at this point in the guide.
    • Using the spudger, carefully pry the battery connector upwards out of the socket. Do not fully remove the battery yet.
    • Now using the tweezers, carefully remove the ribbon connecting the battery from the hardware.
    • The battery isn't held in by anything, so it can fall out of the case if turned upside down.
  6. PS Vita Slim Battery  Replacement: stap 6, afbeelding 1 van 1
    • Now the battery is removable and the process should be complete. You should be free to do what is needed.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Daniel Woodard
3.160 Reputatie
7 handleidingen geschreven
1Gids Commentaar
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
Jack Wallis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 27
Afgelopen 7 dagen: 190
Afgelopen 30 dagen: 894
Altijd: 43,091
