Inleiding
Note::: taking apart your device may void the warranty on the device, please proceed with caution and consider having it sent in first if possible to be worked on by the company. This guide will help you replace the back camera of the PSVita Slim in case anything has gone wrong with the device. This guide should be simple and easy to follow. As long as you take your time and you are careful you should be able to complete the replacement process with ease.
Wat je nodig hebt
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
So first we must remove the casing, remove the two 6.35 mm screws using a J00 screwdriver.
After the screws have been removed, carefully remove the black casing.
4 andere personen hebben deze handleiding voltooid.
